mar schrammeyer
385 -
Posts posted by mar schrammeyer
It is the fill setting that gives the color to the lines but turning of the lines still makes the parking space invisible so no thicker lines, workaround could be "convert copy to lines wireframe" and give it the desired thickness
Maybe try back/foreground render settings?
It depends if they are on layer or screen plane it seems
Indeed it actually walks down the slope, I tried it with other skylites and same thing
Try this button
post a picture of your problem or vwx?
Oz & NZ only I think
after selecting detailer tool you can set default by clicking detailer too prefs button
Like this?
artistic render line & shadows, tried that?
After creating your space and using your selection tool you should see 1 or 2 handles within your space to manipulate your label, if you click within the space (not the handles) you move the space.
Please create a signature it might help in some cases
top left corner worksheet, see screenshot
anther little trick I recently discovered right click
a worksheet on drawing, there will be recalculate
and all worksheets in the file will be recalculated
use the extract surfaces tool
After double clicking your VP check tick box Display Viewport Cache
file/export/batch pdf
don not know about vectorscript but you could put the menu comand show/hide guides under right click tobthe same effect non?
is there actually a crop object to edit? Try this, when in VP crop mode make a new crop object as you want to edit, VW will not alow two crop objects
Hi all anyone, VW does not respond to keyboard shortcuts most menu items are greyed out even quit, will have to force quit. have already restarted once
it still autosaves
Only use background render and setting in that case
Sometimes when I grab a dimension to move it, it will jump to the other side of the wall and I have to move in opposite direction to get it where I want it. Anyone else sees this happening?
redstick icad
Does anyone know how to insert a new sheet and have all numbers adjust automatically, as when I want to insert a new n? 4 the old n? 4 becomes 5 etc, as it is I get a warning "that name exists already in use by an existing layer"
Any input much appreciated
It was a suggestion that possibly fixes the problem, as you can see I have 2 different iMacs of which neither show this problem.
a hard drive cannot do a full repair on itself a better result is achieved by using another mac or external startup drive or even an usb stick with OS.
I suspect the mac behaviour is not related to VW
extrude along path segments
in Architecture
Posted · Edited by mar schrammeyer
I thought I found the problem, I cannot replicate the kinks in a new file but when I try it in your file the lines are there. I used the polyline tool in bezier vertex mode to create the path in both files. Maybe someone in the higher echelons will see the problem
