1. So, then what are the implications regarding this inability to synchronize the plant list with the utility? Once I have customized the Plant Reference List, does it mean I will run into problems should I ever want to import a new plant list into reference list via the utility?
2. Also, I'm back to thinking that the plant reference list is significantly flawed, at least for my purposes. Following your instructions, I've customized some of the attribute values. Unfortunately, it turns out that the combination values you suggested do not work well when custom filtering. Using your example, I created a "Wet Feet and Drought" value under Tolerances, and a "Sand, Loam, Clay" value under soil range (among other potential combo's), to reflect the fact that many, if not most, plants can tolerate a range of conditions. Now, say I want to set up custom filter to select plants for a sandy site that is drought prone, but never wet. When I set up a custom filter to search for drought tolerant plants that can grow in sand, none of the plants assigned a combination value will turn up, as I must enter the exact character string used in the field.
I am not a happy camper... I based my decision to purchase Landmark largely on the basis of the plant database, which would now appear to be largely unreliable.
Also, I think it is misleading for VW to use the term plant "ranges" if I cannot in fact select a range of conditions.
