If when you use the File > Open Recent menu, you encounter this error message:
This normally indicates that the file has been moved from the location it was in when Vectorworks last accessed it.
This does not indicate a problem with the file itself, you will simply need to locate the file on your machine and then either double click it, or use File > Open in Vectorworks and select the file manually.
Edited by JimW
Report Article
There are no comments to display.
