  • Sign in to follow this
    Cloud Job File Failure
    PVA - Jim
    File was deleted locally, causing a deletion on the cloud server
    Deleting a file locally prior to its job completion will delete the file on the cloud server, causing the job to fail once it switches from “Queued…” to “Processing”.  The same result occurs if you move a file to a different folder prior to its completion.
    mcd files are not supported
    Only vwx and PDF files are supported at this time
    Beta files are not supported
    Beta Vectorworks file versions are not supported
    24 hour job processing time limit
    Jobs are currently capped at 24 hours.  Jobs taking longer than 24 hours will be marked as failed.
    File crashed while processing
    Your file may have crashed Vectorworks in the cloud.  You can try to export the file yourself locally during a Batch Export PDF and updating out of date viewports to determine if this is the possible cause.
    The Vectorworks Cloud Services team is alerted any time a job failure occurs.  To help us gather important pertinent information, please ensure your desktop client is configured to report failures (defaults to on).
    It is often useful to have bug report and test file to help us track down specific instances.  If you would like to file a bug report and submit a test file please visit: http://www.vectorworks.net/support/bugsubmit.php
    Edited by JimW
      Report Article
    User Feedback
    There are no comments to display.
    Guest
    Add a comment...
      Only 75 emoji are allowed.
