  • Connecting Compulite VectorPC to Vision 2.3PC via Art-Net
    PVA - Admin
    There are a few things you need to know in order to properly configure the Compulite VectorPC offline editor for it to work properly with ESP Vision.
    This discussion is valid for the following configurations:
    Computlite VectorPC to Vision 3 MAC (different computers)
    Computlite VectorPC to Vision 2.3 PC (different computers)
    Computlite VectorPC to Vision 2.3 PC (same computer)
    CONFIGURE Compulite VectorPC SOFTWARE
    Step 1: After launching Compulite VectorPC software, click on the tools button. Then go to Settings.
    Step 2: Click on the DMX Protocols tab on the menu bar.
    Step 3: Uncheck the VC boxes. Then check the Art-Net boxes. After doing so, Click on the Art-Net button on the right to run Art. The Art-Net Subnet should then display a zero. Now click apply and ok.
    Now, you should be able to patch your show (or load an existing show), and you should be good to go.
    Step 4: Now launch ESP Vision, then click on the DMX in the menubar...Select Change DMX Provider...Change the provider to Art_Net.
    Edited by JimW
      Report Article
    User Feedback
    There are no comments to display.
    Guest
    Add a comment...
      Only 75 emoji are allowed.
