Hello,
I would like to create a worksheet database whose criteria are "select all walls with the Pset_WallCommon IFC value Reference IWS-1**
because here is the wall style Mark I want to use to divide my walls
I tried the string
=DATABASE((('Pset_WallCommon'.'Reference')='IWS-1**'))
but it gives me no results, like it cannot read the IFC property
When I use that field in a spreadsheet it requires the string
=GETIFCPROPERTY(‘Pset_WallCommon’.’R
@MartinaL
There is no default criteria for accessing a pSet Property value as part of a Criteria.
But there is a handy dandy function called DatabaseByScript that will allow you to put whatever you can script into a database.
Copy the script below and paste it into a new Vectorscript names PsetValueAsCriteria.
Create a database row and put in some criteria as a place holder. Right click on the database header row (i.e. 3, not 3.1, 3.2, etc) and cho
