I'm demoing a possible new render machine. I'm currently running 2019 but using 2020 for the demo. The test file I'm using was created in 2019 and it rendered the files correctly. When I opened it up in 2020 and the usual "this file needs to be converted to 2020 blah blah blah" popped up. Everything converted correctly and showed up as it should. I made a minor change so the viewports would need to be updated. Upon trying to update the viewports with fast or final quality Renderworks, the viewpo
There was a bug (Windows-only, fixed in 2020 SP2) where VPs might show black when default image compression preference was set to JPEG (instead of the default which is PNG compression). Don't know if that is the issue here. If it is file specific that helps to know. If it is machine-specific that is helpful to know too. Can you strip out any proprietary stuff you can't share and post the VWX file here so we can try it?
