Hi there folks and friends,
at the moment, i am checking different ways on how to get a correct LED light,
here you see my test file:
rendering with a glowing material makes the render a bit quicker, but i don't have that photometric light
that comes with an ies file.
so waht is your suggestion on an LED-stripe that you can buy from OSRAM and so on.
The one's you attatch on the lower side of your kitchen furniture or tv shelf.
Like u
Ambient On, Default On is the normal state of a new blank document in Vectorworks before any lighting options are altered or any light objects added.
Ambient Off, Default On is what happens when you have no light objects, but have manually disabled Ambient lighting in the render style or in Set Lighting Options for the document and is the state that Luis' tip is designed to avoid.
Ambient Off, Default Off is what you get when you add a light object, but turn it off, and also have Ambient l
