AndyM 1 Posted March 29, 2003 The XL bundle adds 5 plugins. I am not familiar with the details of what they all do, but they are not needed for animation. Quote Share this post Link to post
Kevin 1 Posted April 9, 2003 Hi Hunter; I was wondering if you tried Dave's suggestion and if it worked for you. I tried it and there was no improvement. Quote Share this post Link to post
Hunter B 0 Posted April 14, 2003 I finally just stopped the process... I render as much as it gives me then do it again from the failure point... then I go in and edit the two,three,or four short annmations together... it sure is a pain. Does anybody from VW know anything else about the problem?? We haven't heard a word from you guys in a couple of weeks...are you guys still trying to solve this?? Quote Share this post Link to post
Kevin Beacham 0 Posted April 17, 2003 I read with interest these animation crash problem. Over a year ago I tried to create a reasonably complex animation and I couldn't get it to render more than 16 frames. Imagine my dissapointment when I bought a Dual 1Ghz Power Mac with 1.5Ghz of ram and was getting consistent memory error problems. I gave the file to a VW beta tester who had comments about object grouping, the amount of lights in the animation, and that the model was simply too complex. (The reason I bought the package was to do complex rendered animations). Luckily the animation was for my CV and I didn't have a client waiting for a final product. Anyway it all got too hard. Now I see that C4D (and plugin) is the proposed animation and rendering solution. It looks like it got too hard for Nemetschek to. Quote Share this post Link to post
Philip 0 Posted April 25, 2003 Hi There Guys ! I've been reading about your problem and have to say I have the same ? I have rendered some scary designs but have just in the last two weeks run in to the hanging problem ? I do not get any error messages ? VectorWorks 10.2 just hangs on me ! I am from South Africa and $600 is like 6,000 rand in local curency (my months salary) ? so I need VectorWorks to create my animation ? Not another program ! Hoping, No PRAYING for a solution ! Quote Share this post Link to post
ChadLeeper 0 Posted April 25, 2003 Couple thoughts on this - for what they are worth: Would undo levels have anything to do with this? Also it sounds like interaction of light sources on the objects is imperitive gauging from the descriptions above. However, if this is not the case, one big breakthrough that occurred to me awhile back is that you have a virtual movie studio with your computer complete with motion control. This enables you to perform several "less complicated" passes that can be composited later in Quicktime Pro. However, such a solution is not ideal as of yet (at least with Renderworks 9) as no alpha channel can be made requiring the user to use color mattes - which gets tricky. (thumbs up for alpha channels in future versions!) Granted, only a possible workaround in the least, but thought I'd throw that out. Continued luck in solving it! Quote Share this post Link to post
Hunter B 0 Posted April 29, 2003 HELLO TECH FOLKS..... has anybody solved this problem yet!!!??? it seems that we are left swinging in the wind.... I have not heard anything from the tech folks for a couple of weeks.... can somebody reassure me that this problem is being investigated!!! Quote Share this post Link to post
Guest Posted April 29, 2003 It's been being looked into per my comments on the board. If it's fixed in VW, it's not going to be a single patch. When it is fixed, it will be in one of the updates for the future. I can't speculate as to when it will be fixed or in an update until the final version is available to the public. Quote Share this post Link to post
ErichR 0 Posted May 7, 2003 Here's another twist. I had trouble with rendering stalling on frame 29, or so, JPG format, on a Mac Powerbook G4, 500mhz, 1g ram, VWA 9.5.1. However, on the PC W98, 500mhz, 500m ram, VWA 9.5.1 it sailed right through. Quote Share this post Link to post
