BJRobinson Posted August 8, 2022 Share Posted August 8, 2022 Hi all. I have done my research both here and online and cannot find the way to make a skillion roof. Can someone please point me in the right direction. Cheers Quote Link to comment
Tom W. Posted August 8, 2022 Share Posted August 8, 2022 The simplest way is to create a Roof Face. Or you can create a Roof then edit the edges to convert them from hips to gables. See AEC > Create Roof... + AEC > Create Roof Face I'm assuming you mean how do you create a mono pitch roof if I've misunderstood apologies 1 Quote Link to comment
Jeff Prince Posted August 8, 2022 Share Posted August 8, 2022 @BJRobinson as Tom suggests, a roof or roof face will do the trick. Alternatively, a skillion can be made with a slab fairly easily. After that, you are looking at solid modeling or 3D faces. Quote Link to comment
Tom W. Posted August 8, 2022 Share Posted August 8, 2022 26 minutes ago, jeff prince said: Alternatively, a skillion can be made with a slab fairly easily. Good point! Although a nice thing about Roofs/Roof Faces is that they can clip or be clipped by Walls - on a component by component basis if desired - so it means you can get things looking correct in section, which may or may not be useful in this case Quote Link to comment
BJRobinson Posted August 9, 2022 Author Share Posted August 9, 2022 Thanks Everyone. Create Roof face it is. looks easy enough. I didn't even know it existed. It shows I mainly draw landscapes doesn't it 🙂 1 Quote Link to comment
Matt Overton Posted August 11, 2022 Share Posted August 11, 2022 I believe you can also use a roof with 3 sides set to be gable ends then the roof will add in the walls to infill each side of the roof. 1 Quote Link to comment
Guest Wes Gardner Posted August 11, 2022 Share Posted August 11, 2022 Use the Roof Face command...you can also frame it using the Framing tools - AEC > Framing > Roof Framer Wes Quote Link to comment
