Bill Posted August 6, 2022 Share Posted August 6, 2022 Hi, I am experimenting with the 2022 trial version. After looking at the Help, am I correct that: 2D & 3D Sections are only available in the lower priced Fundamentals version Section Viewports are only available in the higher priced Design Suite version? I.e. with the mid priced Architect version I cannot create a section. Thanks, Bill Quote Link to comment
rDesign Posted August 6, 2022 Share Posted August 6, 2022 (edited) No - this is not correct. The Architect version is one of the Design series products and it can create any type of section viewport. The Design Suite is all of the Design Series products (Architect, Landmark, Spotlight) bundled together. Take a look at THIS PDF from the help file which shows which commands & tools are in each versions. Edited August 6, 2022 by rDesign added table 1 Quote Link to comment
Bill Posted August 6, 2022 Author Share Posted August 6, 2022 Thanks for the good news. The reason I thought that Architect didn't support Sections was: https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Viewports2/Cutting_sections.htm Cutting sections In the Vectorworks Fundamentals workspace, the cutting section commands define ... and Creating section viewports (Vectorworks Design Suite required) https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Viewports2/Cutting_2D_sections.htm the Cut 2D Section command (Vectorworks Fundamentals workspace only) https://app-help.vectorworks.net/2022/eng/VW2022_Guide/Viewports2/Cutting_3D_sections.htm From the Vectorworks Fundamentals workspace, the Cut 3D Section command Thank You 1 Quote Link to comment
rDesign Posted August 6, 2022 Share Posted August 6, 2022 On a related side note, Interior Elevations are one type of section viewports that are available only in Architect, not in the other Design Series products. 1 Quote Link to comment
