cessna310 Posted August 6 Share Posted August 6 I've started using the create stage tool under event design in Spotlight. I can create a stage but if I want to go back to the original polygon and try a different configuration of platform sizes I can not see a way to do that. Is it possible to go backwards other than using CTRL-Z to get back to where I started (and as a side effect undo changes I want to keep)? Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted August 8 Vectorworks, Inc Employee Share Posted August 8 Hmm, good question, I don't think this is possible as create stage creates individual plugs and decks. If it created a plug in object like the seating section tool then you would be able to edit the boundary and copy and paste the original shape. It is a single executable command. If you want to be a bit more free form consider just using an extrude and then edit with the pushpull tool. If you need the 2d shpe back to create a floor or whatever here is a workaround... Stage Boundary Final.mp4 Quote Link to comment
