Spell Check in Project File Sharing
We have problems running the spell check when we have individuals in their working file.  For instance, it seems we can check out a sheet, manually select the blocks of text ont he sheet and run the spell check without a problem, but this is tedious as there mights be 5 or 100 individual or so sheets.
However, if we run a spell check on the design layers or multple sheets we have the problem of the spell check going through all the document, getting to the end and then freezing, or causing the file to crash and then disconnecting to the master file so not been able to save and commit and changes from that person.
Are other people having this issue?  We are working around it by only doing a spell check when one person has their working file open and everyone else is closed - but this is far from ideal.
