Marc Posted December 10, 2002 Share Posted December 10, 2002 Got a question: I'm doing a pretty basic render, one light, no textures, final quality. I'm exporting image file: photoshop, best, 4500 w x 3100 h It takes about 10 minutes to go through the whole process but at the very end says that I'm out of memory. 20 minutes before I was able to export with all the same settings albeit a slightly different view. Does this have to do with the undo thingy? pbg3 500 256 9.2.2 vw 9.5.3 no other programs being used m Quote Link to comment
Guest Posted December 10, 2002 Share Posted December 10, 2002 What do you have set for the min and preferred memory allocation settings for VW? Do you have 256 or 500 mb of RAM? ( I didn't understand from your bit at the bottom on your post. ) Quote Link to comment
Marc Posted December 10, 2002 Author Share Posted December 10, 2002 256 ram I started with 80000 and droped it down to 55000 I ended up lowering the res to 4000 x whatever and it worked. m Quote Link to comment
Guest Posted December 11, 2002 Share Posted December 11, 2002 Marc, You can increase the preferred to about 100,000 and be in the safe zone. Make sure you restart the computer after doing so to ensure all the leftover cache is emptied and cleared. Quote Link to comment
