Dom Posted October 18, 2002 Share Posted October 18, 2002 Hi, How could i create a texture, on an extrude or a plane surface, that would have a light placed behind it with an object between the light and the surface itself, and be able to see the shadow casted from the object on the front side of the surface(opposite side to the light and object) AKA seeing the shadow casted THROUGH the surface, without seeing through the surface itself? VW & RW 9.5 Mac... p.s. any good compromise suggestion would be welcome too.. :-) Quote Link to comment
AndyM Posted October 18, 2002 Share Posted October 18, 2002 Hmmm....The only way I can think to pull that one off in VW is to remove the object that you want to cast the shadow through, render at an angle where your object is fairly square to the viewer. In photoshop crop out the object with the "magic" shadow and reapply the image as a texture on to the original. Maybe someone else can think of a more direct way to do it. Quote Link to comment
MikeB Posted October 18, 2002 Share Posted October 18, 2002 Andy, that sounds about right, I don't think there is any way to do it directly. Quote Link to comment
Guest Posted October 24, 2002 Share Posted October 24, 2002 I've run into this before with customers. Unfortunately, this is a limitation of the rendering engine. Quote Link to comment
Dom Posted October 25, 2002 Author Share Posted October 25, 2002 Tanks a lot, maybe i could try to create a semi transparent window, like eroded plexyglass... Quote Link to comment
