michnov Posted July 28, 2022 Share Posted July 28, 2022 First im do the front rectangle, second from top view, third left/right view. Then im press script and first rectangle becomes a 1st viewport and going to 1st sheet layer etc. Quote Link to comment
Pat Stanford Posted July 28, 2022 Share Posted July 28, 2022 If you are running a version higher than Fundamentals, take a look at the the Create Multiple Viewports command in the View menu. This will get you all the viewports, but they will all be on the same layer. What you want is certainly scriptable if you really need the functionality. But your request is not nearly detailed enough to base a script on. What view are you in before you run the script? What names do you want the viewports to have? What names do you want the layers to have? What scale should the viewports be at? What size should the sheet layers be? Probably 20 more things that have to be defined to get the script to do what you want it to do. Too many times I have jumped in and helped create a basic script to do what someone asked only to find it being an endless string of "Oh, it would be nice if it could just to THIS also." Define what you really want and I will help you write the script. 1 Quote Link to comment
