Isolines in rendered views
Erik Buijs
Erik;
I was also having this problem and posted to this board on 8/23/02. I was guided to changing the 3d Coversion Resolution setting.
For a solution that does not involve buying the upgrade, try going to File>Preferences>Vectorworks Preferences>3d>3dConversion Resolution. Set to Low and see if this helps. I had this set to high and ended up with hundreds of lines on my curved walls. Setting it to Low solved the problem.
quote:
Originally posted by Erik Buijs:
And Katie, when I said isolines, I actually ment the renderlines. I sometimes still use terms of AutoCad! Sorry!
Note that isoline is a technically appropriate general term for what you are describing, although a person may need to be reasonably well informed about geometry or topology to know what you mean by it.
