MarcelP102 Posted July 23, 2022 Share Posted July 23, 2022 (edited) Script to select similar objects based on the objects sub-type or parameter. How it works Select an object and run the script. It will try to detect the type and use a smart criteria to select similar objects. This works better than the default 'Select Similar' Tool of Vectorworks because it uses object styles and parameters to select. For simple 2d objects it select objects based on the same type and class. For plugin objects (PIO's) I've scripted custom criteria based on parameters I think are useful for selection. For example @Paolo mouldings can be selected based on profile type/size. I can add more custom PIO's on request. Hope it speeds up your workflow! DownloadGet it on Gumroad for free Feedback? Suggestions? Request? Let me know! Edited July 23, 2022 by MarcelP102 2 Quote Link to comment
