  • 3
Add option to disable modifying 3D symbols with the 3D modeling tools
MarcelP102
Right now when using the 3D modelling tools, like for example the push-pull tool, it also works on 3D symbols. Turning the 3D symbol into a solid.. So we really have to check all the time if we are editing the 3D symbol. Otherwise you make it a solid by accident. An option to disable this, or a message saying that you are turning a 3D symbol into a solid would really help.
Some illustrations
 Step 1 - 3x the same symbol
Step 2. - using the push pull - but forget to open the symbol edit mode... oops, it turns into a solid..
Step 3 - but this is what I wanted..
Edited by MarcelP102
1 answer to this question
