BenTait Posted August 14, 2002 Share Posted August 14, 2002 Can anyone tell me how to map a single image over several 3d polygons. The polygons are part of a mesh. Breaking the image up is just to slow. Ben Quote Link to comment
Matthew Giampapa Posted August 15, 2002 Share Posted August 15, 2002 Well if you have the 3D PowerPack installed you can do this... 1) Convert the 3D Polys to Nurbs Surfaces (Select a 3D poly, Model menu -> Create Surface from Curves)2) After all the 3D polys are converted (A script is in order if you have a lot of 3D polys) Select all the Nurbs surfaces and use the "Add Solid" command to turn them into a single object. While the resulting object will have join lines in wireframe mode, it will texture as a single surface. Matthew GiampapaNNA Technical Support Quote Link to comment
