QuickDraw 3D on OS 8.5
Abydo
Does QuickDraw 3D for Vectorworks 8.5.2 work only on OS's higher than 8.5?, I am confused as to why this view option is nonexistent on my mac at work, and present on others. The only difference is the OS. Does that play a role? Or am i missing something else, if so what do I do to get this option in my lists of views?
QuickDraw does work on MacOS 9, but only with VectorWorks version 8.x. In VectorWorks 9 we dropped support for QuickDraw 3D and now use OpenGL for realtime 3D rendering.
Check to see if your Mac at work has QuickTime 5 installed. Since Apple is now pushing OpenGL instead of QuickDraw 3D, it is no longer a default component.
You can still install it under QuickTime 5, but you have to tell it to do a custom install.
Matthew GiampapaNNA Technical Support
