Render nots
VulcanGrip
What version are you installing ?
If you go into View>Rendering, do you see the RW options ?
If you go to File>Prefs>VW Prefs, click on the session tab, then the serial number button. From the drop down box at the top, can you select RW ?If yes, does it have your RW serial number listed there ?
Was RW working in your previous version of VW ?
My copy of RederWorks defaults to the 9.0 directory during installation, even if you don't have one, so if you're like me and frequently click next-next-ok-next without paying much attention RenderWorks will be in the wrong directory and VectorWorks will not recognize it. Make sure you point it to the directory of the version of VectorWorks you are using. 9.0.1 or 9.5.
If you have VW and RW 901 installed correctly, VW 9.5 and RW 9.5 should install correctly - if you are installing from the we or the CD.
When installing RW version 901, yes you need to specify the VW 901 folder for it to install into. There is a readme about installing this under Important Information on our message board.
