Control Point visibility.
Thanks Michael for the suggestion, that didn't make a difference.
I suspect that the control point parameter is only functional in Top/Plan view.
Too bad really. That seems to be the only interactive input with the object when using Vectorscipt beyond the pre-defined end points in the case of a linear object.
@LarryO,
   To the best of my knowledge, there is no implementation of 3D Control Points in Plug-Ins. I have heard many requests for them in the past.
   Assuming you could even see a CP in a Front or Side view you would be looking at it edge-on on its working plane. Grabbing a CP in a 3D view would not allow you to move it in the Z-Direction. I don't have an example to test here, so I'm speaking from faded memory. Sorry, this is not what you wanted to hear.
   I think the only exception to the rule would be a 2D Plug-in placed on a 3D Working Plane. The CP would be visible in 3D views, but it would still be limited to only moving in the Working Plane.
Raymond
Yes additional control point parameters only seem to appear when the plug-in is viewed top/plan.
I was hoping that in any ortho view they would appear.
I was going to reset the y-axis to zero internally each time so that it would only move in an x-axis direction for sliding elements along a linear plugin.
There being no Z adjustment was conceptually helpful.
