matteoluigi Posted July 8, 2022 Share Posted July 8, 2022 Hi, is there any way, possibility, to use the vs.Showclass(), vs.Hideclass(), vs.Layer() commands with wildcards? Afaik you only can use them with exact layer names. A * for any class/layer or “.A-*” for any layer beginning with “.A-“ for example would be great. Quote Link to comment
Pat Stanford Posted July 8, 2022 Share Posted July 8, 2022 You will have to script it yourself as all of those commands require an exact name. If you don't use an exact name with Layer() then you will get a new layer created. If you only need the beginning of the name it will be pretty easy to iterate over the layers or classes. Something like (Vectorscript not Python): For N1:= 1 to ClassNum do Begin S1:=ClassList(N1); S2:=Copy(S1,1,2); If S2='A-' then ShowClass(S1); End; Or for a more general purpose, do the compare using SubString instead of Copy. HTH 1 Quote Link to comment
twk Posted July 9, 2022 Share Posted July 9, 2022 AFAIK those layer calls cannot use wildcards. Here's some code for design layers you could use to adapt for classes as well. # First build a list of design layers def get_design_layers(): layer_names = [] layer_handle = vs.FLayer() while layer_handle != None: layer_type = vs.GetObjectVariableInt(layer_handle, 154) # filter out design layers only. (1 = Design Layer, 2 = Sheet Layer, 3 = Referenced Layer) if layer_type == 1: layer_names.append(vs.GetLName(layer_handle)) layer_handle = vs.NextLayer(layer_handle) # we now reverse sort the layer_names list. For some reason this method retrieves layers in reverse order of the stack shown in the Navigation Pallette. layer_names.reverse() return layer_names # Code for controling visibility of design layers def set_visibility(design_layer_name:str, layer_visibility:int, document_design_layers:[str]): # 0 = Visible, -1 = Hidden, 2 = Grayed if design_layer_name in document_design_layers: # this line makes sure we don't create a new design layer using next line of code vs.Layer(design_layer_name) # only way to activate/jump to the layer we want, this call also creates design layers if the name provided doesnt exist # then we apply visibilities if layer_visibility == 0: vs.ShowLayer() elif layer_visibility == -1: vs.HideLayer() elif layer_visibility == 2: vs.GrayLayer() # Code for filtering visibility of design layers def layer_visibility(layer_name:str, layer_visibility:int, document_design_layers:[str]): # cycle through design layer names, if layer_name parameter matches any design layer in design layer list, apply layer visibilty # Store current layer, this will make sense later cur_layer = vs.GetLName(vs.ActLayer()) for design_layer_name in document_design_layers: if layer_name in design_layer_name: set_visibility(design_layer_name, layer_visibility, document_design_layers) # since we've activated/jumped to the design layer we're trying to control visibilty of, we will jump back to our initial design layer, stored in 'cur_layer' vs.Layer(cur_layer) 2 Quote Link to comment
MullinRJ Posted July 9, 2022 Share Posted July 9, 2022 An easy way to search a string for a prefix is to use the vs.Pos() function. Without looking it up there is a Python syntax that does the same. prefix = "A-" aClassName = vs.ActiveClass() # or any class name if (vs.Pos(prefix, aClassName) == 1): vs.HideClass(aClassName) OK I looked it up: prefix = "A-" aClassName = vs.ActiveClass() # or any class name if (aClassName[0:2] == prefix): # grab 1st 2 chars and compare vs.ShowClass(aClassName) Raymond 2 Quote Link to comment
MullinRJ Posted July 9, 2022 Share Posted July 9, 2022 My Python is rusty, and I was curious. Here are two simple scripts to Hide and Show classes with a prefix entered by the user. HIDE CLASSES: import vs # Prompt user for a prefix, then Hide all classes with that prefix. prefix = vs.StrDialog("Hide Classes w/ Prefix", "") ClassL = [] for I in range(0, vs.ClassNum()): # build list of class names ClassL.append(vs.ClassList(I+1)) for aClassName in ClassL: # test all names in list if (aClassName[0:len(prefix)] == prefix): vs.HideClass(aClassName) SHOW CLASSES: import vs # Prompt user for a prefix, then Show all classes with that prefix. prefix = vs.StrDialog("Show Classes w/ Prefix", "") ClassL = [] for I in range(0, vs.ClassNum()): # build list of class names ClassL.append(vs.ClassList(I+1)) for aClassName in ClassL: # test all names in list if (aClassName[0:len(prefix)] == prefix): vs.ShowClass(aClassName) Have fun, Raymond 1 Quote Link to comment
matteoluigi Posted July 9, 2022 Author Share Posted July 9, 2022 @MullinRJ At least I chose your code, because it was the simplest one (and adoptable for either classes and layers,...) Now I took another step and instead of using a StrDialog i tried to handle the prefix in a variable as well. Unfortunately I didn't make it working: import vs; vs.SetLayerOptions(5) prefix = ['.','Keine','WBW'] # this should be the list of all possible prefixes ClassL = [] for I in range(0, vs.ClassNum()): # build list of class names ClassL.append(vs.ClassList(I+1)) for aprefix in prefix: # test all prefixes in list vs.AlrtDialog(aprefix) # test, wether the prefix list really works - test passed for aClassName in ClassL: # test all names in list if (aClassName[0:len(prefix)] == aprefix): vs.ShowClass(aClassName) Good Idea (i thought), but, somehow only the 'WBW'-Classes have been set visible. I don't understand, why.. I also made a test with "vs.AlrtDialog(aprefix)" - and the "for prefix in prefix:"-loop indeed passed all prefixes in the List. classvisibilities.zip I attached a/the test file as well. 1 Quote Link to comment
MullinRJ Posted July 9, 2022 Share Posted July 9, 2022 (edited) Hi @matteoluigi, One letter off and the whole thing comes tumbling down. It took me several minutes to spot it, so don't feel too bad. You are getting the length of the LIST "prefix" (always 3), and not the VARIABLE "aprefix". Change this: if (aClassName[0:len(prefix)] == aprefix): # prefix is a List of length 3 To this: if (aClassName[0:len(aprefix)] == aprefix): # aprefix is an element of List prefix and you are good to go. All else looks good. Raymond Edited July 9, 2022 by MullinRJ 1 Quote Link to comment
matteoluigi Posted July 11, 2022 Author Share Posted July 11, 2022 On 7/9/2022 at 2:09 AM, twk said: AFAIK those layer calls cannot use wildcards. yeah, using a wildcard in vs.Layer instead creates a new Layer named * Pity, that there doesn't exist a function like vs.ClassList for Layers as well, sth like "vs.Layerlist" (with all layers, design layers and sheetlayers, of course...) 😉 Quote Link to comment
Pat Stanford Posted July 11, 2022 Share Posted July 11, 2022 You can do it, and the code is really not much longer. H1:=FLayer; While H1<>Nil do Begin S1:=GetLName(H1); {Do Wildcard stuff here putting result of change into a variable S2} SetName(H1, S2); H1:=NextObj(H1); End; And no you are not allowed to ask why you have to use GetLName to get a layers name and just SetName to change it. Nor are you allowed to ask about why the FLayer command is in the Layers category while NextObj is in the Document List Handling category. 😉 2 Quote Link to comment
