Gobo Projection
psmith
I installed Spotlight, and think there are some great things in it. Two problems I am having are: the drawing that I double-click on to start does not open; only Vectorworks does. The other thing is that the gobo projector tool seems to insert a solid disk in the light source, which means that NOTHING comes out. I have tried editing the gobo, to no avail. Maybe if I set the intensity to 400%, it will burn a hole in the gobos!
quote:
Check your rendering settings to make sure they match what is presented in the manual. You must make sure that you are using raytraced rendering, that you have transparency turned on, and anti-aliasing has to be set to smooth edges and textures.
HTH
Kevin M.
Product Manager
VectorWorks SpotLight
<kmoore@nemetschek.net>
