calculation with recordsheet values that doesn't make sense to me (0,250*1000 =2,0 and not 250)
I want to read out the size of German void Objects (Schlitze & Durchbrüche).
Afaik it's a float variable in the record format 'Break Opening CW','Delta_x''Break Opening CW','Delta_y', 'Break Opening CW','Delta_z'
I don't want to read out the numbers in 0,xxx meters but in xxx cm. So i multiply the value by 1000.
however the result from the script operation is never xxx but always either 0,xxxxxxxx-e01m or x (also all void objects do have a 0,xxx size and I multiply that 0,xxx size by 1000)
I also created a worksheet, which reads out the same variables.
='Break Opening CW'.'Delta_x'*1000
='Break Opening CW'.'Delta_y'*1000
here the multiplication does work instead
2084655650_Bildschirmfoto2022-07-06um15_32_10.png.569d73f1ddc0a6d5acaa4ba6ced0046f.png
131406631_Bildschirmfoto2022-07-06um15_33_23.png.8122a1b9b3d69f49323823c41f0d5252.png1643955291_Bildschirmfoto2022-07-06um15_33_28.png.d2dd4ee8dacd3cb294ff0a57e2833fcb.png
that's so strange to me. 0,250*1000 should be 250 and not 2,00, 0,500*1000 should be 500 and not 5,00...
I tried a lot, Num2StrF, Num2Str(0,...), multiplication by 1000000, no multiplication,... every time I use Num2Str 0,xxx changes in x.
I don't really understand, what's going on there...
( i also attach the vwx 2022 SP3 file)
def parentobjectcheck(SDBH):
	HNDL=vs.GetParent(SDBH)
	SDBx = vs.GetRField((SDBH),'Break Opening CW','Delta_x')
	SDBx = vs.Num2Str(2,SDBx*1000)
#	SDBx = vs.Round(SDBx)
	SDBy = vs.GetRField((SDBH),'Break Opening CW','Delta_y')
	SDBy = vs.Num2Str(2,SDBy*1000)
#	SDBy = vs.Round(SDBy)
	SDBz = vs.GetRField((SDBH),'Break Opening CW','Delta_z')
	SDBz = vs.Num2Str(2,SDBz*1000)
#	SDBz = vs.Round(SDBz)
	vs.SetRecord(SDBH, 'DB-BAUTEILKUERZEL')
	vs.SetRField((SDBH),'DB-BAUTEILKUERZEL','01 Bauteilkuerzel',(vs.Concat(SDBx,'-',SDBy,'-',SDBz)))
vs.ForEachObject(parentobjectcheck,"(INSYMBOL & INOBJECT & INVIEWPORT & (PON='Break Opening CW'))")
void-dimensions.zip
vs.GetRField always returns the String value of the field and appears to be returning the unit mark as well. Str2Num does not handle the unit mark for that you need to use vs.ValidNumStr.
Something like this seems to work.
	B1, SDBxR = vs.ValidNumStr(SDBx)
	SDBx = vs.Num2Str(2,SDBxR*1000)
