Rendering transparency
remarkr
Huh, I just tried it and your right. I don't use the Render Bitmap tool much and I thought that it was tied to the custom renderworks options, but even when I set the custom options to use transparency it dosen't. Not with the render Bitmap tool or the custom Renderworks.
I think its a bug.
Mike,
thanks for your reply. it didn't even occure to me that there was a "Use transparency" option in the prefrences. I don't know how may times I've opend that box & never noticed it.
I went in and turned it on and it worked for me. So, as far it not working for you, maybe the transparency needs to be set higher on the shader your using.
Thanks again.
