Leonard Marsh Posted August 2, 2001 Share Posted August 2, 2001 I successfully placed a text decal on a building element made from part of an extruded oval. Wow! The problem: I want the text directly mounted to the building, not to a signboard, and the finish material showing. The questions are: 1. Can a text element be exported with a transparent background as a jpeg or equal without losing the transparency from PhotoShop or Illustrator? (VW recommends using image-editing programs like PS or Illus.) 2. Is there anything that can be done to make the background transparent once imported (bit-mapped) to VW/RW? TIA, L. Quote Link to comment
MikeB Posted August 2, 2001 Share Posted August 2, 2001 In RW9 you can assign the background as transparent. This is not possible in VW 8.5.2, but I would recommend you create your text in VW then use the "True Type to Polyline" tool to make the text into an extrudable object. In 8.5.2 there is some clean up that has to happen (you have the clip the voids out of "0" and "B" etc.) but in 9 it works beautifully. Then once you extrude it you can apply any material you want. Good Luck Quote Link to comment
Leonard Marsh Posted August 8, 2001 Author Share Posted August 8, 2001 MikeB, Thanks for the help. I'll give it a try. L. Quote Link to comment
AndyM Posted November 2, 2001 Share Posted November 2, 2001 I have heard much mention of being able to make the background of an image transparent with RW9 but I have had ZERO luck in actually doing it. What's the trick? Quote Link to comment
MikeB Posted November 4, 2001 Share Posted November 4, 2001 You need to have 2 copy's of your texture. One of the image with a white background, and another that the image is all white with a black background. The second image can have no color and no gray scale, just a white image on a black background.The go to Resources PaletteSelect "New"Select "Texture"Under "Color" Select "Image color"Select your first image (in color with white background)Then go to "Transparency"Select "Image mask"Select you second image (White w/ Black background)Set your scale for your imageYour Done I've made some people and trees using this technique. It works pretty well. You have to have VW and RW 9 for any of this to work and it only works with the Ray Trace Rendering Engine. Good Luck Quote Link to comment
Guest Posted November 4, 2001 Share Posted November 4, 2001 Here is a 'How To' I created that was in the Summer Dispatch. This may help. http://www.nemetschek.net/support/technotes/render_mask.html Quote Link to comment
