Spaces - How to add Occupant Loads to Labels?
I don't believe you can do that using the built in labels of the Space tool unless you manually do the calculation and put the value in one of the UserFields or one of the occupancy fields and use that in the label.
You might be able to use the Datamanager to do the calculations and populate the occupancy fields, but I am not positive.
You can definitely do the calculations in a Data Tag and have it show all of the information about the space and not use the built in Space Label.
Oh, well... It would be great if there was a way to have a numeric Additional Information field to allow this.  I am sure that most architects would love to have this feature incorporated into the Space Labels.
Thanks for the suggestions!!!!!
