troypwms Posted May 7, 2001 Share Posted May 7, 2001 What is the deal! (MAC G4/Tons of RAM SSW 9.0.4) Renderworks 9 will not render your model if you create a texture, map it correctly, duplicate it and then swap the image keeping the same resolution and feature size. It will calculate geometry, and then give you a black picture in a few seconds. If you then remove the new duplicated texture from the file it will freeze the system. Tech Folks: What is up with this new version??? Wasting time, Troy Williams KWDG Quote Link to comment
MikeB Posted May 8, 2001 Share Posted May 8, 2001 Troy I've done the exact same procedure several times with no problems. What do you mean by tons of Ram What is your VW allocation You might want to upgrade to OS 9.1 its a free download from apple. Good Luck Quote Link to comment
troypwms Posted May 8, 2001 Author Share Posted May 8, 2001 I Have 850MB of RAM in the machine and anywhere from 250+ allocated for higher res renderings... I'll try 9.1... Thank you. Troy Quote Link to comment
troypwms Posted May 8, 2001 Author Share Posted May 8, 2001 9.1 No Better... Lots of crashes and freezes. I feel as though this upgrade was a waste of money. I'm going to export and work with 8.5.2. Please provide a solution and update soon. Troy Quote Link to comment
