SamIWas Posted June 26 Share Posted June 26 I went way outside my normal world and used vector script to create a mesh of an object which I couldn't build using standard script tools. I built the object in Vectorworks, then exported it as a 3d vector script to get the mesh coordinates. Then I added all that into a script that I am writing to build that part of the object. That all works exactly as intended. BUT, I want to be able to scale that mesh with user input. So, I added some scaling fields into the OIP. Cool. All that is great, except at the mesh doesn't scale. Here's a general layout of the code: BeginGroupN(groupname); BeginMesh; ClosePoly; *a bunch of 3d poly coordinates* EndMesh; EndGroup; Now, I have tried HScale3d both just after EndMesh with LNewObj as the handle, and after EndGroup with "group name" as the handle. Neither seems to have any effect. Is there a step I'm missing here to scale a mesh overall? Quote Link to comment
Pat Stanford Posted June 26 Share Posted June 26 It appears that HScale3D does not work on meshes. Procedure Test; BEGIN AlrtDialog(Concat(GetTypeN(FSActLayer))); HScale3d(FSActLayer, 0,0,0, 2,2,2); End; Run(Test); Draw a rectangle, extrude it (or push/pull) and run the script. It doubles in size. Convert the solid to a mesh and run the script, It does not change size. The menu commands Scale... does work on meshes, but requires the dialog box. No good suggestions. Sorry. Quote Link to comment
Pat Stanford Posted June 26 Share Posted June 26 OK, I found a work around that might work. Convert the mesh to a solid, scale it, then convert back to a mesh. I THINK the reason that HScale3D does not work is that under the hood a Mesh is effectively a group of 3D polys. And HScale3D does not work on groups. Try this and see if it will fit your needs. Procedure Test; Var H1:Handle; N1:Integer; BEGIN ClosePoly; BeginMesh; Poly3D(-1,0,0, 1,0,0, 0,-1,1); Poly3D(-1,0,0, 1,0,0, 0,-1,0); Poly3D(-1,0,0, 0,-1,0, 0,-1,1); Poly3D(1,0,0, 0,-1,0, 0,-1,1); EndMesh; N1:=AddSolid(LNewObj,LNewObj, H1); HScale3d(H1, 0,0,0, 2,2,2); DoMenuTextByName('Convert to Mesh', 0); End; Run(Test); Quote Link to comment
SamIWas Posted June 26 Author Share Posted June 26 13 minutes ago, Pat Stanford said: OK, I found a work around that might work. Convert the mesh to a solid, scale it, then convert back to a mesh. I THINK the reason that HScale3D does not work is that under the hood a Mesh is effectively a group of 3D polys. And HScale3D does not work on groups. Try this and see if it will fit your needs. Procedure Test; Var H1:Handle; N1:Integer; BEGIN ClosePoly; BeginMesh; Poly3D(-1,0,0, 1,0,0, 0,-1,1); Poly3D(-1,0,0, 1,0,0, 0,-1,0); Poly3D(-1,0,0, 0,-1,0, 0,-1,1); Poly3D(1,0,0, 0,-1,0, 0,-1,1); EndMesh; N1:=AddSolid(LNewObj,LNewObj, H1); HScale3d(H1, 0,0,0, 2,2,2); DoMenuTextByName('Convert to Mesh', 0); End; Run(Test); That did the trick. Don't even need to convert it back to a mesh. Quote Link to comment
