Mohammed Posted June 24 Share Posted June 24 Hello There, I am working on a model creating soil surface (landscape area) with elevation input detail. When i enter z- level (64.732) it rounds up to (64.75). How to get the exact value of 64.732 Quote Link to comment
Anders Blomberg Posted June 26 Share Posted June 26 I do believe that if you input 64.732 the modell will update with that exact value. But values in Object info palette asf will only show you precision as set up in the units preferences. Check what's selected under "decimal precision" and "decimal rounding base" under file/document settings/units. Unfortunately I believe this setting also affects the precision of dimensions. Personally I'd like to modell with a precision of .001 m but have dimensions show a precision of 0.01 m. I use the dual dimensions setting to have the dimensions show mm values for certain parts. Someone else might know if this is possible and also verify if I'm correct in my assumptions. Quote Link to comment
Amanda McDermott Posted June 27 Share Posted June 27 That's how I understand it too. 1 Quote Link to comment
