Hi,
A lot of times when working in 3D I want to use the Working Plane but my view got blocked by objects in front of the plane. The Clip Cube can help with that. But it takes a lot of time to setup. That's why I decided to make a script that sets the Clip Cube based on the active Working Plane. Since there are no functions available to set the position of the Clip Cube I used a trick to make a huge extrusion on the workplane and use that to set the boundaries of the Clip Cube. This works for most user-cases but unfortunately not for rotated Working Planes. @Marissa Farrellcan you throw in an enhancement request for more control of the Clip Cube with Vectorscript?
Step 1: Set Working Plane
Step 2: Look at Working Plane, view gets blocked
Step 3: Run Script, view gets unblocked
PROCEDURE ClipCubeByPlane;
{Sets the Clip Cube position equal to the Working Plane.}
{Since we cannot rotate the Clip Cube by script this work best with Working Planes on X and Y.}
{© 24-06-2022 Arnhem - The Netherlands, Marcel Plomp}
{Licensed under the GNU Lesser General Public License}
VAR
	H1							:Handle;
	xRot, yRot, zRot 			:REAL;
	p0X, p0Y, p0Z 				:REAL;
BEGIN
		{Turn off Clip Cube}
		SetPref(6707, FALSE);
		DSelectAll;
		{Create big extrusion}
		BeginXtrd(0,-1000000);
			rect(-1000000, 1000000, 1000000,-1000000);
		EndXtrd;
		{Get workplane coordinates}
		GetWorkingPlane(p0X, p0Y, p0Z, xRot, yRot, zRot);
		{Move object to workplane}
		H1:=LNewObj;
		SET3DRot(H1, xRot, yRot, 0 , 0,0,0);
		Move3DObj(H1, p0X, p0Y, p0Z);
		{Enable Clip Cube and delete object}
		SetPref(6707, TRUE);
		DelObject(H1);
END;
RUN(ClipCubeByPlane);
This would be very useful! Or somehow to make a Clip Cube automatically align/rotate to a selected object on creation (I am forever activating the Clip Cube, rotating it to align with the model then creating a Saved View).
As a secondary point, @MarcelP102 you are making scripting look really easy it is very inspiring well done!
  • 1 year later...
