Shortnort Posted June 22, 2022 Share Posted June 22, 2022 Is there a link to a video on creating door hardware sets? I have created door types with specific door hardware set numbers, but occassionally I need to change some door hardware items, so the hardware set assigned is no longer applicable. The door schedule will not allow me to modify the hardware set. So - is there a way or must I creat a new door type just for this minor change? I am really surprised at the very limited info available on door hardware. Any links or suggestions are welcome. Quote Link to comment
Guest Wes Gardner Posted June 22, 2022 Share Posted June 22, 2022 @Shortnort door hardware is stored as a symbol...you can create your own and save them in your user folder...the symbol will be in your Resource Browser...you can right-click and Edit 3D Component and then "Save As" for your own custom hardware Wes Quote Link to comment
techdef Posted March 3, 2023 Share Posted March 3, 2023 Wes, I've done this, but cannot find the edited hardware symbols from within the Manage Door Hardware dialogs. Any guidance there? Quote Link to comment
Tom W. Posted March 3, 2023 Share Posted March 3, 2023 After saving your 3D symbol in your 'Door - Hardware' user folder you then need to make a 'Hardware Set': go to 'Manage Hardware...', click on 'Add...', in 'Edit Door Hardware Set' dialog create new Hardware Set using your symbol: Now this hardware set will appear in the list + you'll be able to use it (probably need to refresh libraries first). 3 Quote Link to comment
