LarryO Posted June 21, 2022 Share Posted June 21, 2022 Where would I locate the setting that determines the LOD view when operating in the layer environment? At the moment within my test file the visualization when in a layer is generating medium LOD. Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted June 21, 2022 Vectorworks, Inc Employee Share Posted June 21, 2022 The setting is called "Auto display detail levels for design layers" in the Document Preferences dialog. BTW: There's also an "Auto display detail levels for design layers" quick pref to toggle it on and off. Quote Link to comment
LarryO Posted June 21, 2022 Author Share Posted June 21, 2022 Thanks Matt, I got it working! I will PM you the result of my concrete screw anchor plugin. The data file is a bit shy because the manufacturer (Hilti) that I attempted to emulate doesn't publish the thread pitch and number of turns of thread. I only had a selection of 1/2" profiles on hand and the pitch data listed in the file for the 3/8" diameter is from a different manufacturer (Simpson). Quote Link to comment
Vectorworks, Inc Employee Matt Panzer Posted June 27, 2022 Vectorworks, Inc Employee Share Posted June 27, 2022 On 6/21/2022 at 7:25 PM, LarryO said: Thanks Matt, I got it working! I will PM you the result of my concrete screw anchor plugin. The data file is a bit shy because the manufacturer (Hilti) that I attempted to emulate doesn't publish the thread pitch and number of turns of thread. I only had a selection of 1/2" profiles on hand and the pitch data listed in the file for the 3/8" diameter is from a different manufacturer (Simpson). Good to hear you got it working! Quote Link to comment
