LOD setting for Layer environment, where?
The setting is called "Auto display detail levels for design layers" in the Document Preferences dialog.
BTW:  There's also an "Auto display detail levels for design layers" quick pref to toggle it on and off.
Thanks Matt,
I got it working!
I will PM you the result of my concrete screw anchor plugin.
The data file is a bit shy because the manufacturer (Hilti) that I attempted to emulate doesn't publish the thread pitch and number of turns of thread. I only had a selection of 1/2" profiles on hand and the pitch data listed in the file for the 3/8" diameter is from a different manufacturer (Simpson).
On 6/21/2022 at 7:25 PM, LarryO said:
Thanks Matt,
I got it working!
Good to hear you got it working!
