Capturing keystrokes
Is it possible to capture if a modifier key was pressed during the drawing of a line that is being used by a path object (drawing a cable)?  If so, how?  If not is there some way to capture an action during the creation of a path object that will modify the processing of the path object?
If you are using GetPtL(), GetLine(), or any of the other interactive functions to draw your path, then YES, you can test the Command, Option, CapsLock, and Shift functions to see if any were pressed when an interactive function was running. If you are using standard VW Drawing Tools, then I don't think so.
I'm not your final authority, so wait to see if better advice arrives.
Raymond
