Texturing exterior walls
Geoff Briggs
geoff-
if you are using artlantis, you can export to artlantis using the VW classes. If you set up your model so that all your exterior walls, no matter what layer they are on, have the same class, then when it goes into artlantis, you just apply the texture to that class, and it will render the entire surface. if you want to have several types of exterior surfaces, just set up as many classes for exterior walls as you may need. this will work for the latest version (3.5) of artlantis. version 3.0 does not support this. as for renderwork, i would not know, since i have used artlantis since before rw was around.
