Steve Barrett Posted June 15 Share Posted June 15 I'm at the beginning phase of working on a rendering and for some reason I'm seeing red crosses at the ends of the truss. Truss in question is Prolyte X30V. I've turned off the truss-cross/insert points/label/magnet and simplified classes and that doesn't have an effect on the crosses. I've also tried editing both the 2d and 3d geometry and even with every class turned on those red crosses are not visible in editing mode. Furthermore the rendering style doesn't seem to matter, they show up all styles. As anyone seen this before and figured out a way to remove the crosses? VWX 2022 SP3.1 Quote Link to comment
Steve Barrett Posted June 15 Author Share Posted June 15 Thanks Pat. I believe my truss crosses are different than what that thread is referring to. The truss crosses in that thread are automatically generated by BW, typically when one truss is laid on top of another (for example). I’m well versed in classing those and turning them off. The truss crosses I’m referring to are at the ends of the truss and ever present. They seem to be hard coded. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted June 16 Vectorworks, Inc Employee Share Posted June 16 The red crosses are the auto-connect attachment points of the truss, not truss crosses (the truss cross issue is being addressed in 2023) and are automatically created based on the truss objects BrxTrussItemRecord (accessed by the Customize Truss Symbol Data command in the right click context menu, not from the data tab of the OIP) Normally they should only be visible in Wire-frame or shaded polygon modes and not in Shaded or Rendered view modes. They will also display if the truss has been converted to a hanging position but this should only happen when the position is selected. This was an issue in 2021 and older versions of the software and as far as I know was fixed for 2022, it works correctly for me (I can only get the crosses to display if I'm in Wire-frame or shaded polygon modes), but I use a win 10 PC not a mac which may be part of the issue. Otherwise from your screen shot it looks like you may be using a customized truss library, since the trusses are black. If it is a custom library do you get the same issue using the default library version of the trusses? When was the custom library created? 1 Quote Link to comment
Steve Barrett Posted June 16 Author Share Posted June 16 Hello Jesse, the trusses are the Prolyte x30v from the straight truss library. I’ve just edited the 3D geometry to use class attributes and filled a dark gray. No custom trusses and these are not hanging positions. And just to confirm, these auto-connect attachment points show up in every render mode I’ve tried, including hidden line etc. I’m on Mac OSX Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted June 17 Vectorworks, Inc Employee Share Posted June 17 I'll get a bug report opened What mac OSX version? and what build number of Vectorworks are you using? Quote Link to comment
Steve Barrett Posted June 17 Author Share Posted June 17 2022 SP3.1 (Build 646432) Quote Link to comment
