Elite Exhibits Posted June 14, 2022 Share Posted June 14, 2022 Preferences 3D Tab - Default 3D view Render Mode / View Projection How do you get the Default 3D view Render Mode / View Projection setting to take effect Please see attached movie Mac OS 11.6.5 - MacBook Pro - VW Designer 2022 SP3.1 (646432) 64-bit Intel i9 / AMD Radeon ¿ What am I missing ? Suggestions are always appreciated ! Peter ************************************************** Default RederMode.mov 1 Quote Link to comment
0 Rolan Castaneda Posted February 28, 2023 Share Posted February 28, 2023 I have the same question. It works on my previous projects, but not my current one. Quote Link to comment
0 Pat Stanford Posted March 1, 2023 Share Posted March 1, 2023 I am not seeing that behavior in VW2023SP3 (or any previous version). It is supposed to do what you are expecting and change the projection and render mode to the defaults when you switch from Top/Plan to a 3D view. Restart VW? Restart Computer? Rename/Move User Folder? Run the Updater and choose Advanced:Repair? Uninstall VW and reinstall? Quote Link to comment
0 Elite Exhibits Posted March 1, 2023 Author Share Posted March 1, 2023 Pat A new drawing with a simple extrude and the 3D Render Mode ... settings appear to work as expected - Edit an older drawing and ?!#%@?! ... I gave up on getting it to work - Leave it set to Wireframe & Ortho. My comment above was from last summer on 2022. New employer and we have backed up to VW/RW Designer 2020 as it is stable. Based on what was/is happening, there may be two potential issues. Open GL / MacBook Pro or Unified View. Finding that Unified View causes a remarkable number of anomalies. Items disappear, Items selected, yet invisible - textures missing in edit group mode - items move while editing a hybrid symbol - rendering different in Open GL compared to Renderworks - etcetera I keep Unified View Off and only Display Screen Objects Checked - On occasion I needed to turn Unified View On to get things to behave. (Odd as this occurs when only a Single Design Layer is in the file. Ref: "What happened to 'Unified View' in v23?" Peter Quote Link to comment
0 Elite Exhibits Posted March 1, 2023 Author Share Posted March 1, 2023 FYI July 2022 - Case number 00270325... Peter Quote Link to comment
0 Pat Stanford Posted March 1, 2023 Share Posted March 1, 2023 Unified View is on by default in VW2023. If you want to turn it off, you have to temporarily activate the Legacy 2D Features from the Document Preference:Legacy 2D Tab. VW2023 also had minimized the use of Screen Plane. Screen Plane is still available and if you update a file that uses Screen Plane then Legacy 2D will automatically be turned on. Quote Link to comment
0 Rolan Castaneda Posted March 2, 2023 Share Posted March 2, 2023 Just uninstalled and reinstalled v2023SP3. It still will not set the default 3D view render. It also did not fix my issue with the Callout Tool text scaling incorrectly. Also, is there another way to access the "Advanced: Repair" option, because when I click Check for Update, it just says "You're up to date", and no other options. Quote Link to comment
0 rDesign Posted March 2, 2023 Share Posted March 2, 2023 3 minutes ago, Rolan Castaneda said: Just uninstalled and reinstalled v2023SP3. It still will not set the default 3D view render. It also did not fix my issue with the Callout Tool text scaling incorrectly. Also, is there another way to access the "Advanced: Repair" option, because when I click Check for Update, it just says "You're up to date", and no other options. Click on 'Advanced Options +' in the Updater, then you'll see the option for Repair. Quote Link to comment
0 Pat Stanford Posted March 2, 2023 Share Posted March 2, 2023 To expand on @rDesign's comment. In you VW application folder there is a separate application called VW 2023 Updater. Run that and follow the directions for Repair under the Advanced Options. Quote Link to comment
0 Rolan Castaneda Posted March 2, 2023 Share Posted March 2, 2023 Okay so I ran the Updater App, clicked repair and re-launched. It is still not saving the default render settings. Quote Link to comment
0 Rolan Castaneda Posted March 2, 2023 Share Posted March 2, 2023 It also did not fix the Callout Tool text scaling issue. Quote Link to comment
0 Pat Stanford Posted March 2, 2023 Share Posted March 2, 2023 Have you tried the New User Account or Move/Rename the User folder steps? It sounds like you might have corruption in you user folder. Quote Link to comment
0 Rolan Castaneda Posted March 2, 2023 Share Posted March 2, 2023 I did not. Can you list the steps to do that? Quote Link to comment
0 rDesign Posted March 2, 2023 Share Posted March 2, 2023 (edited) Make sure you have your VW Serial number handy, you'll probably need it; Quit Vw and open the Finder, navigate to Macintosh HD/Users/ [YOUR USER NAME] /Library/Application Support/Vectorworks/. Inside that folder move or rename the folder named '2023'. If you rename it, name it something like '2023-OLD'. Restart Vw and test. Edited March 2, 2023 by rDesign 1 Quote Link to comment
Elite Exhibits
Peter
13 answers to this question
