Frank Schnater
dashed hidden line rendering
Did anybody notice thatdashed hidden line rendering is not working properly or is it just me: only some items are 'dashed', others (all my walls f.i.) are just rendered 'hidden lines',
Any clues?
tia,
Frank Schnater
(mac 8.6, VW8.5.1)
I had similar difficulty on a PC using VW 8.5.2 with Renderworks. After experimenting with an extruded cube I found the following to occur. If the line thickness attribute for the cube is set to class thickness than the hidden lines will render invisible. If set to a specified thickness I get dashed lines. I tried this with a wall and found the same thing to happen. I hope this helps.
