Elite Exhibits Posted June 10 Share Posted June 10 Mac OS 11.6.5 - MacBook Pro - VW Designer 2022 SP3.1 (Build 646432) Apply a texture from the Resource Manager Info Dialog shows the intended texture - exture does not render with that texture until the thickness is other than zero. Has occurred several times -not all the time an extrude is "zero" - Restarting VW / RW appears to solve the issue for the short term. What am I missing ? - Suggestions Peter Zero Extrude Texture Error.mp4 Quote Link to comment
0 Kevin McAllister Posted June 11 Share Posted June 11 I would imagine the rendering engine is getting confused because the top and bottom surfaces of the extrude would be in the same space. Convert your source surface to a NURBS surface instead of an extrude if you need it to have zero thickness. (Command Option K on a Mac) Kevin Quote Link to comment
Elite Exhibits
Peter
1 answer to this question
