rendering air
RemcoT
Sorry to tell you this but I know the Quick Draw 3-D engine can't, mostly becuse it cannot render transparency. As far as render works I really dont think it will either. For something that sophisticated you need 3-D max or Form Z. Hopefull someone will let me know if I'm wrong
  • 4 years later...
Well, things have changed a lot in VW/RW in the 4 years since I first replied to this [Wink]
I suppose with RW it is possible to creat a geometry to mimic a light cone, and then create a texture for it. With the new shaders introduced over the last few versions I think you could get a convincing result.
Good Luck
It can be done quite easily in fact there was even a tutorial somewhere. Just do a multiple extrude of a couple of circles (one is the beginning of beam and the other is the end) and apply a mostly transparent shader. The BIG hang up is that the beam itself will cast a slight shadow.
