gchianese Posted February 16, 2000 Share Posted February 16, 2000 Please see last message in general discussion under bitmap rendering. I have not gotten a reply. Quote Link to comment
Guest Posted February 16, 2000 Share Posted February 16, 2000 Try this, use the render bitmap tool with different pixel aspect ratio's. You'll find that only the 1:1 setting works properly, especially with larger files. The pixel ratio seems to act as a zoom factor within the selected window. The Bitmap render was made to work with the 1:1 screen pixel ratio. If it is not at 1:1 nothing will appear. You can change the DPI of the BITMAP by selecting the bitmap tool and then click the preference box in the mode bar, in here you can change the DPI to something higher. Quote Link to comment
