Data Tag - Z Position
Hi all, I'm making up a data tag for video screen information and I'd like to add the trim height (bottom trim) but can't seem to find the right command to do it, alternatively just showing the Z axis would work just fine - does anyone know how to show this?
Thanks
Max
The insertion point is normally the bottom edge of the Video Screen. So you could attach a data tag with just that parameter. The Parameter you are looking for therefore is Object Parameters > Insertion Point Z. This should give you #IPZ# which you need to make sure is entered into the "Current Tag Field Definition" within the Data Tag Text definition.
