  • 19
Data Visualisation legend: option to not create
Tom W.
12 answers to this question
3 minutes ago, fuberator said:
possibly stating the obvious: With the viewport(s) selected: choose "none" in the data visualisation popup in the OIP and it disappears
Doing that gets rid of the Data Viz completely. It's just the legend I want to get rid of not the Data Viz itself
Here is the script to remove legends from all viewports.
##This script remove data visualization legend from all view ports on all sheet layers
## Created by Jiajing Qi, Tested: VWX2023 SP1, 01/03/2023
## Use it on your own risk
import vs;
global i
i = 0
vs.Message("This script removed data visualization legend from all view ports on all sheet layers.")
# collect handles of selected VPs on active layer
def GetHandle(h):
	if vs.GetObjectVariableInt(vs.GetLayer(h), 154) == 2:
		if vs.GetTypeN(h) == 122:
			hVP.append(h)
hVP = []
vs.ForEachObjectInLayer(GetHandle, 0, 2, 1)
# Traverse into the annotations group of selected VPs and delete Data Visualization Legend
for VP in hVP:
	anno = vs.GetVPGroup(VP, 2)
	h = vs.FInGroup(anno)
	objs = [h]
	h = vs.NextObj(h)
	while h != vs.Handle(0):
		if vs.GetObjectVariableString(h, 1166) == "Data Visualization Legend":
			vs.DelObject(h)
			vs.UpdateVP(h)
			i = i + 1
		h = vs.NextObj(h)
if i > 1:
	vs.AlrtDialog(f"Removed {i} data visualization legends")
else:
	vs.AlrtDialog(f"Removed {i} data visualization legend")
Hello everybody. Implemented in VW2025 Update 4.
In the create viewport dialogs you can now select if you want to create a legend.
Can it also be added to the Viewport Styles? This way a style update will trigger whether/not the DV legend displays.
Or even assign them a dedicated Class so that they can be turned off en masse via Class Visibilities.
Edited by bcd
