dayv Posted April 7, 2006 Share Posted April 7, 2006 I am having a small issue when inserting windows into walls. The point where the wall meets the window (window jamb) there is a light line, not matching the weight of of the wall class which is what I would prefer that the program do. This has to be a preference problem...right? In additon, we are having the same issue with our wall caps. Little help here! Quote Link to comment
Peter Eichel Posted April 16, 2006 Share Posted April 16, 2006 The VIEW TAB in the preference window has a USE PART LINE STYLES option. Set your jamb line thickness here and make sure the option is turned on in the OIP after you insert your window. Quote Link to comment
