Ride Posted June 2, 2022 Share Posted June 2, 2022 Is there a reason why my T wall joins still show a line at the joint? This doesn't happen with the L joins. Thanks Quote Link to comment
Jeff Prince Posted June 2, 2022 Share Posted June 2, 2022 "uncapped" vs "capped" Join Mode perhaps? Quote Link to comment
Ride Posted June 2, 2022 Author Share Posted June 2, 2022 4 hours ago, jeff prince said: "uncapped" vs "capped" Join Mode perhaps? No, I'm using uncapped mode. Thanks for the reply. Quote Link to comment
MarcelP102 Posted June 2, 2022 Share Posted June 2, 2022 Noticed this to after VW 2022 sp3 update. Quote Link to comment
P Retondo Posted June 2, 2022 Share Posted June 2, 2022 This has always been a problem. Sometimes the line appears, sometimes it doesn't. I have never been able to figure it out. 2 Quote Link to comment
Ride Posted June 3, 2022 Author Share Posted June 3, 2022 6 hours ago, P Retondo said: This has always been a problem. Sometimes the line appears, sometimes it doesn't. I have never been able to figure it out. Well that's unfortunate. I've been trying to figure this out for a long time, and now I know I'm not the only one. It makes my drawings look messy with all the extra lines. Is this better in 2022? I'm not using that much these days - even though I have it. It has some weird graphic issues going on with viewports. But that's for another post. Quote Link to comment
Tom W. Posted June 3, 2022 Share Posted June 3, 2022 On 6/2/2022 at 1:28 AM, Ride said: Is there a reason why my T wall joins still show a line at the joint? This doesn't happen with the L joins. Thanks Does using Component Join in T Join Mode get rid of the line? Quote Link to comment
Ride Posted June 3, 2022 Author Share Posted June 3, 2022 9 hours ago, Tom W. said: Does using Component Join in T Join Mode get rid of the line? Ah ha! Yes it does. I have never seen that type of 'join' before. I only tried it on one instance, but it worked. I use simple walls with only one component as I don't need to show wall construction (this is for millwork shop drawings). Could there be something in my wall construction that is making that line persist? Either way, happy to have a solution for this. It was getting really annoying. Thanks for the help. Quote Link to comment
Tom W. Posted June 3, 2022 Share Posted June 3, 2022 Excellent! 58 minutes ago, Ride said: Could there be something in my wall construction that is making that line persist? I have no idea. I have two very similar single-component wall styles, one joins with a line which I have to subsequently remove with the Component Join tool, the other one doesn't. Wall 1: Wall 2: I can't think what it is about Wall 1 that makes it behave differently. I don't think I have any other walls which do it... Quote Link to comment
shorter Posted June 3, 2022 Share Posted June 3, 2022 Do you have components in one wall but not the other? 1 Quote Link to comment
Tom W. Posted June 3, 2022 Share Posted June 3, 2022 1 minute ago, shorter said: Do you have components in one wall but not the other? Yes both wall styles have components but I just realised the offending one didn't have 'Core' checked! When it's given a core it joins properly without a line. 3 Quote Link to comment
Ride Posted June 4, 2022 Author Share Posted June 4, 2022 11 hours ago, Tom W. said: Yes both wall styles have components but I just realised the offending one didn't have 'Core' checked! When it's given a core it joins properly without a line. Yes! This worked for me too. Thank you all. So helpful. Quote Link to comment
Ride Posted June 4, 2022 Author Share Posted June 4, 2022 Well maybe I spoke too soon. It works on the design layer, but my in my viewport the lines are back. Will work on this some more. Quote Link to comment
