Vectorworks, Inc Employee Robert Anderson Posted April 6, 2006 Vectorworks, Inc Employee Share Posted April 6, 2006 The room name tool is still available. Use the WS Editor to add it to your workspace. Please send your other problems as bugs to bugsubmit@nemetschek.net. Thanks!! Quote Link to comment
islandmon Posted April 6, 2006 Share Posted April 6, 2006 You can always just use a Wall/Floor/Ceiling Finishes Symbol then link Records to Symbol and simply assign values to all the Records/Fields your projects require. That's what I do ... anyway. Seems to work just fine. The Space Procedure requires a polygon to make a polyline to object ID# the space. This is entirely separate from assigning finishes to wall objects , for example. Quote Link to comment
sprague Posted April 6, 2006 Author Share Posted April 6, 2006 Robert - The room name tool is available, but in V.12 you are no longer able to assign room finishes to the room name - unless im missing something? I will send email to bugsubmit. Islandmon - Thanks for your comments. I dont think the space procedure is entirely separate from assigning finishes to wall objects. That is the only way to assign room finishes in V.12. I noticed you are a user since Minicad v1.0 so it sounds like we both know how to create a symbol, link text/records, and create spreadsheets. But, that is much more difficlut than the assign room finish tools in V.11.5 and you dont get to take advantage of an office wide finish library. We might have to do that - as last resort. Quote Link to comment
Kevin Posted April 6, 2006 Share Posted April 6, 2006 quote: Originally posted by sprague: ...1. Space Tool: 90% of the time we import an AutoCad drawing. Version 11.5 we had the option to use the Room Name Tool. The Space Tool, forces us to draw a poly around the room just to put the name in - an extra step we shouldnt have to do. ...Thank you. AEC>Create Polys from Walls>Net Area. Then AEC Objects from Polyline>Space. Now you have all of your rooms populated with Space objects. Quote Link to comment
bonose Posted April 6, 2006 Share Posted April 6, 2006 Use the WS editor to transfer the "Room Name" tool into the Dims/Notes set (or any other set as you see fit). The "Room Name Simple" tool already resides in the set and will not let you assign finishes as this one will. Quote Link to comment
sprague Posted April 7, 2006 Author Share Posted April 7, 2006 As an interior design firm, Room Finish Schedules are obviously an important part of our business. Switching to version 12 has been a step back in time and reminds me of MiniCad version 3 or 4. Does anyone else have problems? or solutions? 1. Space Tool: 90% of the time we import an AutoCad drawing. Version 11.5 we had the option to use the Room Name Tool. The Space Tool, forces us to draw a poly around the room just to put the name in - an extra step we shouldnt have to do. TECH SUPPORT AND PROGRAMMERS - Using the space tool is fine, but dont force me to draw a poly around the space when it really is not needed. 2. Materials: We have always used the Assign Room Finishes tool, and created our own library of finishes. Our library consists of T-1 for Tile, C-1 for Carpet, Etc. In Version 11.5 if we had two materials on the floor in the same space, we would use the Assign Room Finishes Tool, then add additional finishes in the Object Info Box. TECH SUPPORT AND PROGRAMMERS - We need a way to add more than one finish to each space. We often have several finishes on floors, walls, and ceilings. 3. Remarks Column: What happened to the remarks column? Does no one else add remarks? We almost add remarks. TECH SUPPORT AND PROGRAMMERS - We need a remarks column. 4. Tech Support: I have already contacted Tech Support and gone through these problems. After no solutions, the advise was to post something to this board, because alot of the senior tech support and programmers read the board and can make changes to the program. I hope that is the case. I have used the program for almost 15 years, and although many of the changes in Version 12 are great, the changes to room finish schedules do not allow us to do our jobs efficiently. If Tech Support or anyone else has solutions to our problems, please let me know. Thank you. Quote Link to comment
Ramon PG Posted April 9, 2006 Share Posted April 9, 2006 quote: Originally posted by sprague: 3. Remarks Column: What happened to the remarks column? Does no one else add remarks? We almost add remarks. TECH SUPPORT AND PROGRAMMERS - We need a remarks column. The Remarks dissapeared but check if there's a Note column as in doors and windows. Quote Link to comment
islandmon Posted April 9, 2006 Share Posted April 9, 2006 "... But, that is much more difficlut than the assign room finish tools in V.11.5 and you dont get to take advantage of an office wide finish library. We might have to do that - as last resort." Yeah... I know but ... it's Hard to teach Old Dogs New Tricks... or make them jump thru toomany hoops before lunch ... ; ) soon come ... soon Quote Link to comment
Ramon PG Posted April 12, 2006 Share Posted April 12, 2006 quote: Originally posted by Ramon PG: quote:Originally posted by sprague: 3. Remarks Column: What happened to the remarks column? Does no one else add remarks? We almost add remarks. TECH SUPPORT AND PROGRAMMERS - We need a remarks column. The Remarks dissapeared but check if there's a Note column as in doors and windows. I checked and there isn't one. I had to use the old "data-editing" method. And assign the proper link in the Schedule so that it shows. Here's the link I use: =('Room Record'.Remarks) I only wish these inconsistencies were better explained at update time so that we may save our valuable time for designing (which is what we like) and invoicing!!! (hopefuly). Quote Link to comment
sprague Posted April 12, 2006 Author Share Posted April 12, 2006 Thanks Ramon, but now that you have the column, how do you put a comment into it? I used to be able to type the comments in the data field, but its no longer there. Quote Link to comment
Ramon PG Posted April 14, 2006 Share Posted April 14, 2006 sprague: ...use the old "data-editing" method. Go to the Data tab in the Obj Info palette and enter the comment there. Did you enter =('Room Record'.Remarks) in the database row of the Door Schedule? Also remember you can always edit the column text header in the schedule (as long as you don't touch the record) to whatever you like: Note, Remaks, etc. [ 04-14-2006, 10:00 PM: Message edited by: Ramon PG ] Quote Link to comment
