The Hamma Posted April 5, 2006 Share Posted April 5, 2006 I would like a way to turn of fills in Top/Plan projection, ideally in View ports. This would be convenient in making Electrical and RCP plans with out turning off the fills on the Floor Plan. Does any one have a solution that is not global? Quote Link to comment
CipesDesign Posted April 5, 2006 Share Posted April 5, 2006 Create a CLASS w/ attributes (fills.hatches, etc), then place all filled objects into that class(es). In your VP's, use the VP Class Overrides to change the attributes of each pareticualr class. This can be done a "per-VP" basis, IOW, you can change a class's attributes as desired for each VP. HTH's Quote Link to comment
